Brand new Adobe Reader 2015 is out and Adobe installs file rdrcef.exe which continuously sends info to Amazon.
Hard blocking rdrcef.exe is therefore a given as the only way to prevent third party servers having contact with our files, but it would be nice if there is a way to disable it in registry or options, please post if/when you find out how.
While it is important for this program to get updated continuously due to obvious security concerns, Adobe appears to have made updating mandatory, taking away our choice between security and stability. Before 2015 DC version just came out, I know for a fact that some version 11 releases, like 11.0.9 was buggy and I did not install it on certain machines with unimportant disposable content on which we need STABILITY more than security, on which we
only install updates which have been
confirmed as stable on our systems.
So if anyone figures out how to disable automatic updates only, please post.
P.S. Of course there are excellent alternatives like
http://www.sumatrapdfreader.org/download-free-pdf-viewer.html
but that's not the point of this thread
EDIT: SOLVED:
If you want to use eServices then great, if not, here's the reg file to disable interaction between the files you read and cloud storage:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\Acrobat Reader\DC\FeatureLockDown\cServices]
"bToggleAdobeDocumentServices"=dword:00000001
"bToggleAdobeSign"=dword:00000001
"bTogglePrefSync"=dword:00000001
"bUpdater"=dword:00000000
