- Apr 26, 2012
- New York, USA
- Thread Starter
- #21
Noctua industrialPPC 2000RPM PWM
They come in both 120mm and 140mm so you can use the 120mm fans on your rads and 140mm for your other case fans.
Would it be beneficial to have the extra heat surface of 140mm rads? I picked the 120s specifically for fan options, but if those fans come in 140, why not get the bigger rads too, right?
Edit: These are the fans you were talking about, right?
