- Feb 8, 2003
Hi All.
After many years of using AMD cpu's I just moved to a new Intel rig. This is the setup so far.
DFI Infinity
P4 - 2.8c (SL6WJ) w/ Antec Aeroflow 1
2 x 256 PC4000 (3-4-4-8 @ 2.6v)
ATI 9600XT
80 Gig Maxtor
CrystalFontz 634 USB LCD
After setting up a fresh install, which by the way, was very easy and trouble free (compared to a usual AMD XP/NForce 2). I made sure everything was running to spec.. I went for the overclock next, and this is where I am at -
P4 2.8c @ 3.3 @ 1.585v (236x14) - Primed @ 19 hours, Memtested @ 14 hours - 3DMarked @ 8 hour loop. - Stable.
Idle - 22 -- Load - 38 (MBM 5 reading)
Ram is at default settings (as above)
ATI 9600XT @ 572/640
I can't budge anything past 240 - I run memtest and it fails/locks up on "Test 0" - What does that mean?
Any suggestions on where to go from here? At 3.3, it's not shabby at all but in reading alot of posts and looking at the database my stepping seems to get a bit higher results ...
Would a Asus (P4C800) or a Abit (IC7-Max 3) make a difference here? I could return this Infinity and pick up either of the above?
Thanks for taking the time to read...
DFI Infinity
ATI 9600XT
80 Gig Maxtor
