Afterburner resets voltage when i restart!
mysticjbyrd
Is this supposed to happen? I changed afterburner to 1.15v with default fan curve. I start it today, and it's at 1.25v, boost voltage, and the fan curve is off. I change it, restart, and it's back it 1.25v again.
Lochekey
Senior Pink Member
It has been awhile since I have touched afterburner, but if it is anything like precisionx you will have to save a profile with the changes you want and then tell afterburner to apply that profile at startup. You will also need to set up afterburner to start with Windows if it is not already.
ATMINSIDE
Did you save the profile?
Did you set the profile to load at startup?
Does Afterburner run at startup?
Edit: Basically what Lochekey asked. PrecisionX is just a reskinned version of Afterburner with a few tweaks applied.
Nebulous
Señor Senior, Senior
The Empire State
I've been having issues with AB also. Voltage resets, fan profiles fail to work, but overclocks on core/ram stay. Reboot and my video goes black for insufficient voltages on my clock. Uninstalling didn't help. I have to go to a restore point to uninstall AB. What a freakin' pain :rolleyes:
Using Sapphire Trixx for the time being. No issues thus far with it.
