So I spent most of this weekend tearing my new PC down, adding new parts, fans or cables, then rebuilding, then tearing down again to reroute or reorganize something or other, then rinse and repeat.
So now my CPU bounces to like 94°C on Prime 95, which is definitely something new. I thought it was because I remounted my radiator to be a side exhaust and that with airflow running top speed from bottom to top, it was reducing the static pressure of my EK Vardar fans on the radiator. But I just finished rebuilding everything with the radiator back on top and it didn't make a difference.
So here is my setup, now with all ARGB and new sleeved black & white cables -
And in red:
And with a flash to show the cabling better -
So after rebuilding the 'proper' way, with the radiator on the top, I am still getting 94°C temps on P95.
The only thing I can think of is poor contact with my CPU from the waterblock. Before it wasn't a problem, you can see here my temps after about 1h running P96 Small FFTs concurrently with Furmark AND MSI Kombustor -temps were not bad at ALL:
And that was with just 3 case fans, a 120mm exhaust, and a 120mm and 140mm intake (plus the 3 exhaust from the AIO through the rad).
New setup is now 6 120 intake and 4 120 exhaust.
So when I was rearranging things, I had to take off my waterblock to rotate the hoses as one wouldn't point downward - I'm assuming now I have poor contact. I didn't replace the thermal paste, it's just the factory EK stuff the AIO came with. I supposed I can use some old AS5 I have, or I can order some Hydronaut or Kryonaut. I think I'll go that route, my AS5 is at least 10 years old, although when I checked it a couple weeks ago it still seemed plenty viscous.
Any of you guys have a recommendation on Hydronaut or Kryonaut?
And in red:
