maybe I'm a little late, but I'm glad I paid only 35 € / $ for each mainboard and cpu...
1. What color is the box your Alby came in?
purple
2. What Bios do you currently use?
110
3. What is your P4 STOCK Speed?
mobile Celeron 1800 256 KB L2 C1
4. What is your P4 OVERCLOCK Speed?
3060
5. What is the fsb of your P4 Overclock?
170
6. Do you use the manual divide the pci or use the 66/33 lock?
lock
6a. If you use the maual divide, what is the current setting?
7. What is your current video card installed?
ATI Radeon 9000 non-pro 285/490
8. How much memory to you have installed?
256 MB TwinMos PC 400 CL 2,5
9. What is the stock memory setting (ex: 333)?
400
10. What is the overclocked memory setting?
454
11. What are your current memory settings (ex: 2-6-3-3)?
2,5-7-3-3
1) how many sticks are being used
1x256
2) if they are double or single sided modules
single
3) what slots are they in. Consider 1 is closest to the cpu, and 3 is farthest from the cpu.
slot 1
1) what is cooling the cpu
Artic Cooling Super Silent 4 80mm @2250 rpm
2) what is cooling the NB
no fan, origonal heatsink, no changes
Vcore 1,675V Bios setting (MBM 1,65V)
Vdimm 2,8V
temperature load 52 C / idle 30 C
power supply 350W 12V 16A
