Greetings. Let's get down to business, shall we? I have an AMD FX 9590, with a 'CRYORIG H7' cooler on it. In the past, I had an issue with the CPU's core speed going up and down (from 4700 to 1300) on load. Was discovered my current motherboard didn't support the powerful CPU.
So I now have a 'GA-990FX-GAMING' motherboard, that does support it. Had to reinstall Windows (it was required). Ran AIDA64 Extreme (trial version) on it, and at exactly 1 minute and 47 seconds in, the computer shut itself down when the CPU reached 78*C. A friend of mine suggested I try disabling (in BIOS) cool and quiet, C1 C6, and turbo (and also underclock it to 20x frequency, and 1.43V).
I'm now using Prime95 (with Core Temp to monitor the temps) to stress test. Ran it for 4 hours (though 'Light FFT'), and the highest it got was 60*C. I was happy, but I knew I had to run it through the two hour 'Blended' test. Was going to attempt to do it the next day. Turned my computer off as usual and went to bed.
This afternoon, I attempted to turn it on... and it turned itself back off a half a second after I hit the power button. Tried it again, this time I heard “*beep*…*beep*…*beep*…*beep*…*beep*" coming from the computer(like, two beeps a second, then turned itself off again). Sometimes it was two beeps until it turned off. My fear went through the roof, trying to figure out what the hell did I do to deserve this.
After the forth time, I heard ten of these beeps (and then stopped when the POST screen popped up)..but thankfully my computer went through POST and booted normally.
I was able to run the 'Blended' test later on for the two hour timeframe, and it passed with flying colors. The temp stayed in the 50's (with the highest temp range between 56-57). So this is great. This means it's stable, right? Yet with this new issue with my computer not being able to boot properly until I attempt to turn it on a 4th time.. yeah. Plus my friend tells me it's possible I may have to reset BIOS to its factory settings, to fix this issue (which would undo the underclocking).
My friend recommended I make an account with you guys, and ask. I'm hoping I get an answer that solves both issues. I don't want to be forced to have to RMA the 9590 back to Newegg.
I can understand the beeps (for being an overheating issue) if I had turned it off and then back on again..., but I had it off for a good 8 hours, which should give the CPU more than enough time to cool down.
Specs;
OS: Windows 7 x64
CPU: *mentioned in OP*
GPU: NVIDIA GTX 750 Ti
RAM: 16GB DDR3 (4x 4GB setup)
PSU: Antec Earthwatts 650W
Specs;
OS: Windows 7 x64
