- May 27, 2002
- Ohio
i currently have an XP 1700+ palomino ( i couldn't remember what it was...so used sandra-soft to check it )
i want to know, by shorting out certin L3 bridges, would it be likly that i could reach 15x multipliers on this CPU?
And if so, what voltage might be needed for that?
Everywhere i checked, the core voltage for my cpu is 1.82 volts.
But my mobo only allows me to raise the voltage up......like...5%, and 7.5% ( i forget if it allows me to reach 10% )
but i'm not sure those voltages would be enough.
and i don't know if i really want to connect all the L1 bridges.....cause i could short a few L3's much faster and easier than connecting all the L1's.
well......some help would be very......helpfull here.
