- Dec 19, 2012
OC, the Gonster has a really good H2O setup. In my experience with my chip, lower temps lower V core
Quite a noticeable difference!
OC you'll be amazed on how much less Cpu v you need at X clock speed when the chip is running cooler. I can imagine what it would be like if you put the Cpu under sub ambient.Well, that should have occurred to me immediately. Otherwise the LN2 guys would be pushing 1.8v or higher to get their clocks I suppose. Ah fudge another reason I need to stop procrastinating on the cooler situation.
Watched the video where they took the 8350 into the worlds record, amazing stuff and they kept it way below 0
I LoL'd at this GonesterAnd those pots cool a lot of the board around the cpu socket and that hits on the NB and the VRMs which just makes it all the more *gooder*.
I agree with Storm Chaser here, swiftech makes quality products, it's also expandable.I've heard good things about the Swiftech H220 (but don't have any first hand experience with it)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108183
Us "old guys" will be 57 in a couple months.
I will look the coolers over and no I have no issues at all cutting a hole where and if its needed. As far as the radiator fitting....this is a full size case 8.25 x 19.75 x 22.75 so should be room for a decent setup and it not look to bad. Just gotta get rid of those red fans. LOL
Did Dakz find your Sensi bone there Manny?Red fans FTW
