So my problem is I was recommended Scythe Slip Stream 120mm x 25mm Fan - 1600 RPM (SY1225SL12H) for a push pull config on a xspc 360 rx. I set the fans to pull air from the case and vent through the top. Everything seemed fine till one day I heard a clunk and opened my case and found the a core/fanblades resting on the top of my graphics card. I thought at first it was just a bad fan (it happens) and I replaced it. Then I started hearing a sound from the fan blades making contact with the fan body, I checked them and noticed that the fans had slid down the shaft and were on the verge of falling out. I didn't have money at the time to go out and buy all new fans so I just re-mounted the fans to take air from outside of the top of the case and blow into the case. The fans seem to work fine now but I bought a new card that does not have a liquid block on it and I would like to go back to a config where the air is pulled out of the case and vented through the top. So my question is this has anyone used this Swiftech Helix 120mm x 25mm Z-Bearing Fan - 1800 RPM In a water config pulling air out of the case? Meaning the fan core is facing down, and have you had the same problem of the fan core falling out over time? I just don't want to spend a wad of cash and end up having the same problem as the Scythe fans.
