Changes in agesa versions bug up saved profiles unfortunately. But its logical when you think about it.Saved profiles never work after a BIOS update. The same is on ASUS or Gigabyte. ASUS is clearing the list in the last generation, so you can't even try to load it. A different code causes issues. Some years ago, when profiles were still listed after an update, I had the wrong values after loading profiles from different BIOS versions.
It's a bit weird, but the last BIOS update fixed the coil whine in idle on my ASRock B650E PG ITX. It also caused training and boot times to be shorter. These were the two most annoying things in this motherboard.
Edit:
New ASUS BIOS has this in the description:
"Update AGESA version to Combo AM5 PI 1.0.8.0 to support upcoming CPU."
I think it will be APU.
Interested if the 1.0.8.0 agesa has performance impacts? I head through the grapevine they were implementing fixes for malware exploits & it will impact performance not sure if this is true or not.
