Hi,
I'm having a lot of difficulty in overclocking my ASUS A7V266-E/Athlon XP 2100+ based system. Actually this machine is overclocking quite smoothly BUT the computer will not POST again on a 'cold boot' with ANY overclocked or manually set FSB speed setting other than the 1.72 ghz/133 mhz FSB nominal setting for the Athlon XP 2100+.
Even if I UNDERCLOCK the board at the 100 mhz FSB 'safe mode' setting, this computer will not POST again after a powerdown. Only the nominal setting for the Athlon XP 2100+ of 1.72 ghz/133 mhz FSB will allow the computer to POST on cold boot.
Strangely, I can manually set all kinds of FSB speeds and reboot with the new setting just fine as long as I don't power off the machine. As I write this message I have my computer overclocked to 140 mhz FSB and 1.82 Ghz CPU. Everything is rock stable, I can run Flight Simulator 2002, America's Army, Raven Shield, any CPU intensive application I can think of and nothing flinches one single bit. I can reboot all day and all night without a snag - BUT - if I powerdown completely and do a cold boot it will hang on POST again. Very weird.
Only resetting the nominal FSB speed again will allow a cold POST, no other setting under or over this will POST on cold powerup.
My CPU specs:
CPU: AMD AthlonXP 2100+
Code Name: Thoroughbred
Voltage: 1.68 v
Family: 6
Model: 8
Stepping: 1
Ext. Family: 7
Ext. Model: 8
Revision: B0
My ASUS Mainboard specs:
Model: A7V266-E
BIos: 1015e beta
Mb revision: 1.07
Major Components of my System:
512 MB Kingston PC2100 DDR memory
SBLive! Value 128 PCI soundcard
Gainward Geforce 4 Ti4200 AGP 8x video card
Antek 400 watt ATX 2.01 Power Suppy
I am using a Thermaltake Orb Heatsink with silicon free silver type thermal paste, intake and exhaust fans in my case tower, and am maintaining excellent CPU temps when overclocked. Heat is not a problem obviously.
I have tried BIOS versions 1011 and currently, 1015E beta, no difference in the two regarding this issue. I have also tried boosting the CPU core voltage but this has no effect either. This really seems like a defective EPROM chip at this point, I'm not sure.
I would greatly appreciate any advise or anysight anyone might have on this issue, thanks a lot!
My CPU specs:
Voltage: 1.68 v
Family: 6
Model: 8
Stepping: 1
Ext. Family: 7
Ext. Model: 8
Revision: B0
Model: A7V266-E
BIos: 1015e beta
Mb revision: 1.07
