- Thread Starter
- #21
Looks like I'm not done just yet.
I'm running into issues reinstalling Windows XP 2005 MCE. I have the version that's two Windows CDs plus a 2005 rollup CD. Problem is this: When it does the initial command line install, it copies files from disc 1, then reboots. Then it comes back up with "Press any key to continue....." If I press a key, it goes back to the same installation menu I was just at. If I don't press a key, it freezes with the words still on the screen. From what I'm reading, Windows should boot at that point to continue the setup, but it doesn't. This happens when I boot from CD... when I boot from HDD, I just get a blinking cursor that never goes away. An improvement over a black screen, but not by much
I used the recovery console to run FIXBOOT on the install drive and FIXMBR. I deleted, remade, and formatted the partition, and tried giving it both the full 20 GB and the 15GB split to leave room for Ubuntu. Not sure if this matters, but during the format the partition went from being a "System" drive to a plain NTFS drive. My understand is that doesn't matter, and the System drive is determined by where the system files are placed once the installation continues, but I want to make sure.
Do you think I need to track down a floppy drive so I can make a RAID driver disk from the ASUS utility CD? There's an option to add RAID drivers during Windows installation by hitting F6, but only from the A: drive, and since I'm installing to a SATA HDD that may play some part even though they're set to IDE mode.
