- Aug 19, 2012
Right i am back and thanks for sticking with me!! Well from what you just said, maybe we should look at the PSU, But before we do that check all the power connections first and is this in a case or on a box outside!!
I just thinking if you have a earth short some where, maybe we should check out all of it. That's the stand off's if its in the PC Case, because one of those could turn things off.
And what PSU are you using for this build my friend??
Are you using the Q CONNECTOR to put all you connections too!! If you are try taking it off the Mobo and use the on board start and reset buttons instead. The reason if you have the wires the wrong way around it will cause a short and the MOBO will not fire up!!
