- Dec 28, 2002
- USA
The Audigy in my opinion is one of the WORST soundcards, either i had completely wrong settings, or this is a terrible machine
Rafterman223 said:I can't even tell the difference between integrated audio and audigy...*sigh*
specific said:
maybe you aren't an audiophile, or you're listening to the wrong sounds. or you must have nvidia integrated sound? because if you can't tell the difference between some cheap integrated stuff i've heard and an audigy card, you should invest in some q-tips.
audigy doesn't suck, it's much better than their old cards.
never had a problem, nice clean sound.
Johnny Knoxville said:we know it's crap, go read the sound card debate in the debates section to see how much creative suck
KLowD9x said:
Yeh, the NVidia integrated sound is quite nice. A friend of mine just purchased the A7N8X, and it features this...his 15" kicker SLAMS now, more than before.
MEAT BAG said:
Im sorry but hows does that make it "slam" more. He probly just turned the bass up. I thought voltage outputs were standerdized. Or the previous card wasnt reproducing all the frequencies of the material.
Richard said:
The simple truth of the matter is that for PC applications any modern PCI sound card (chip) is going to produce sound quality along the same lines. If you're obsessed with high end audio - obviously there are better choices. However, I seriously doubt anyone looking for such a product would be reading overclockers.com.
