- Feb 28, 2004
- UK
My specs are in my sig...
My scores:
3dmark01se = 16862
3dmark03 = 6383
What is wrong with my 3dmark01 score? A mate (Freddie, hes around here somewhere) agreed that that was a bad score. I have Kingston Valueram on standard timings, thinking of getting some new ram sometime. The temperatures in the sig seem correct, if I turn my case fans off, the load temperature soars over 40c. The cpu heatsink feels cold to touch too. The 9800pro/xt runs very hot though, don't know exact temp as only the real xts have temp probes. C drive is defragmented (where windoze and 3dmark is). I have closed as many background programs as I can. I haven't started stopping services. I may try installing another windows installation on my new 120gb sata drive and try it with that, with everything i can uninstalled/turned off.
Also, my clock is at 158mhz x19. My vcore is 1.6v (+200mv) If i put it up to 166, i get a blue stop error at the start of the windows loading screen. With the vcore at 1.65, I get the stop screen at the end of the windows loading screen, or the screen turns off (standby mode, ie no signal from the gfx card) and the hard disk light is solid on. with the vcore at 1.7 i get the same.
Any ideas?
My scores:
3dmark01se = 16862
3dmark03 = 6383
Any ideas?
