- Jun 29, 2005
- Over Here!
I'm rebuilding my HTPC again and am stuck searching for a power supply... I've read the stickies, been all over JG's reviews and OW's as well... I know which brands to buy, but I'm trying to save a few bucks on this build without skimping on the psu
Here's what I'm working with...
1 x Asrock Extreme4 Z77 Mobo
1 x 3570K cpu w/ Stock Heatsink for now - (Stock settings, least amount of power/heat is the plan, maybe OC down the road, but still will want to stay @ stock volts or lower)
1 x 30GB or 60GB SSD
1 x 2TB WD Black HDD
2 x Bitfenix Pro Spectre 120mm Blue fans
Maybe 1 x 460 GPU = This thing is all about the heat... I'm wondering if I'll even need it as this won't be a gaming rig, mainly movies/web/etc...and I can stream through the on board HDMI...
Here are some links to the PSU's I'm contemplating...
Corsair CX500 - $50 AMIR
OCZ ZS 550W (Modular) - $45 AMIR
OCZ ModExtreeme Pro 600W - $45 AMIR
My "budget" is around $50 (after mail in rebate) but I wonder if I even need to get another PSU...
Will I be able to run the above build minus the GPU on a 400W psu? Is running a GPU with the build above on the 400w cutting it to close?
Thanks for your help!
