- Sep 6, 2003
64person timelimitless servers are awesome and the G36 rules
TheGreySpectre said:64person timelimitless servers are awesome and the G36 rules
deathBOB said:EA and Gamespy are cracking down on timelimit removed servers by dropping them from the list...
subtotal said:does the timelimit hack affect singleplayer as well or just multiplayer?
Drec said:it's server side, so no. only mp.
Dracknem said:Is there a way to run the 32 player map singleplayer? wanna practice flying without being online.
blitzkrieg1110 said:u playing on one of the all weapons unlocked servers? how does that work, do you only get the better of the two weapons or can you pick? (ie: do you still get to try out the pump shotgun even though there is an auto unlocked)
whitebloodcell said:i'd like to know that aswell! I cant go online anyways, wont let me register an account for some reason
Sjaak said:Goto multiplayer.
Choose: 'start local'
Then choose the large map.
whitebloodcell said:...can you get bots to play with you on it?
Ha_hA_HA! said:Nope, coop is disabled (unless there is a hack for that too), but you can still practice flying. You can use vehicles as target practice.
well heat seekers cant lock on to a heat source if there is NO heat source to lock on toSjaak said:With the draback that the heatseekers won't lock on anything without a driver (eg, without an engine running)
Contra said:well heat seekers cant lock on to a heat source if there is NO heat source to lock on to
Sjaak said:(eg, without an engine running)
