- Apr 29, 2011
- Anchorage, Alaska
Just as the title says. I'm looking to setup a home file server, and am looking for a good free server OS. Any help is appreciated
I was debating on ubuntu but i have little to no experience with linux
#!/usr/bin/vmplayer
# Filename: ubuntu_test.vmx
# Generated 2011-08-28;06:15:46 by EasyVMX! 2.0 (beta)
# http://www.easyvmx.com
# This is a Workstation 6 config file
# It can be used with Player
config.version = "8"
virtualHW.version = "6"
# Selected operating system for your virtual machine
guestOS = "ubuntu-64"
# displayName is your own name for the virtual machine
displayName = "ubuntu_test"
# These fields are free text description fields
annotation = "ubuntu file server"
guestinfo.vmware.product.url = "http://www.easyvmx.com/"
guestinfo.vmware.product.class = "virtual machine"
# Number of virtual CPUs. Your virtual machine will not
# work if this number is higher than the number of your physical CPUs
numvcpus = "2"
# Memory size and other memory settings
memsize = "320"
MemAllowAutoScaleDown = "FALSE"
MemTrimRate = "-1"
# PowerOn/Off options
gui.powerOnAtStartup = "FALSE"
gui.fullScreenAtPowerOn = "FALSE"
gui.exitAtPowerOff = "FALSE"
# Unique ID for the virtual machine will be created
uuid.action = "create"
# Settings for VMware Tools
tools.remindInstall = "TRUE"
tools.upgrade.policy = "upgradeAtPowerCycle"
# Startup hints interfers with automatic startup of a virtual machine
# This setting has no effect in VMware Player
hints.hideAll = "TRUE"
# Enable time synchronization between computer
# and virtual machine
tools.syncTime = "TRUE"
# USB settings
# This config activates USB
usb.present = "TRUE"
usb.generic.autoconnect = "FALSE"
# First serial port, physical COM1 is not available
serial0.present = "FALSE"
# Optional second serial port, physical COM2 is not available
serial1.present = "FALSE"
# First parallell port, physical LPT1 is not available
parallel0.present = "FALSE"
# Logging
# This config activates logging, and keeps last log
logging = "TRUE"
log.fileName = "ubuntu_test.log"
log.append = "TRUE"
log.keepOld = "3"
# These settings decides interaction between your
# computer and the virtual machine
isolation.tools.hgfs.disable = "FALSE"
isolation.tools.dnd.disable = "FALSE"
isolation.tools.copy.enable = "TRUE"
isolation.tools.paste.enabled = "TRUE"
# Other default settings
svga.autodetect = "TRUE"
mks.keyboardFilter = "allow"
snapshot.action = "autoCommit"
# First network interface card
ethernet0.present = "TRUE"
ethernet0.virtualDev = "vlance"
ethernet0.connectionType = "nat"
ethernet0.addressType = "generated"
ethernet0.generatedAddressOffset = "0"
# Settings for physical floppy drive
floppy0.present = "FALSE"
# Settings for physical CDROM drive
ide1:0.present = "TRUE"
ide1:0.deviceType = "cdrom-raw"
ide1:0.startConnected = "TRUE"
ide1:0.fileName = "auto detect"
ide1:0.autodetect = "TRUE"
# Settings for the optional virtual CDROM, ISO-image
ide1:1.present = "TRUE"
ide1:1.fileName = "C:\Users\PUTYOURNAMEHERE\ubuntu.iso"
ide1:1.deviceType = "cdrom-image"
ide1:1.mode = "persistent"
ide1:1.startConnected = "FALSE"
# First IDE disk, size 8Gb
ide0:0.present = "TRUE"
ide0:0.fileName = "ubuntu_test.vmdk"
ide0:0.mode = "persistent"
ide0:0.startConnected = "TRUE"
ide0:0.writeThrough = "TRUE"
# END OF EasyVMX! CONFIG
