Best XP bang 4 the buck
OnDborder
Senior Member
HOT 'n Arizona
I'm planning on upgrading my cpu pretty soon.
For the people who know better, what XP is the best performance for the money?
I don't think I'm going to upgrade my MB yet so I'll be using the set-up I have now.
NASsoccer
On a string I was held Senior
i live
i am going to have to say either the 1600 or the 1800. The 1800 is down to around 130 and when unlocked can be overclocked into the xp2000 default range. So, i think that is the way to go at the moment. The 2000 is still pretty high.
peppy
i would say the athlon xp 1700+ it runs at 1.47 but will do xp 1900 anyday of the week, and it is only 108$
peppy
THE AGOGA stepping and agkga are both good steppings, just ask the people u plan to buy from they should know
Yodums
Senior Member
Ottawa, Canada
1600 and 1800.
With 1600, you would be able to get very high bus speeds same with the 1800. 1800 may look more slick since it would get to like 2300+ speeds or something like that.
OnDborder
OnDborder
Senior Member
HOT 'n Arizona
I kinda was planning on buying online..The sales reps rarely know what stepping the chip has.
I think the overclockerzstore is the only site I've seen where they advertise what stepping the chip has.
bobt17
Michigan
if u get the right stepping a 1600+ will do u good just take a look at my sig and it would go higher then that too if my ram werent holding me back (just ordered some pc2700:D)
EDIT: btw yes i am water cooled but i'v had it run as high as 42 or 43 stable this high and i know at least some air cooling can cool it to that temp
maxima88
The Xps run cooler than the tbirds.
My athlon ran 5c hotter than my current XP w/ the same setup.
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
Stephen Castles said:
my friend bought a retail boxed amd xp 1700+ cpu, he got an AGOGA 'Y' cpu......lucky bastage...;)
Should oc well for him. Not to feel bad, this is the sort of luck I have as well.
tyshy
Under your desk:)
how can u tell if it is an agoga stepping or what the stepping is on the chip? Does it say on the chip or does it say on the box when u buy it? Is it a random thing with the cpu's or what? Is there a huge difference and will i pay more?
Silver
Dallas, Georgia
It's on the chip, about the third or so line down followed I believe by the last two digits of the year and the two digit week.
13rian
if no one would mind, could i get an opinion of the same Q [bang for the buck], but in about 3 months where the thoroughbreds will be officially out for awhile, meaning athlon xp prices will be dropping rapidly :cool:
