- Feb 21, 2006
- Glen Ellyn, Illinois
- Thread Starter
- #41
ya im thinking this is the cheapest im going to find it for a while...
Jedi Mind Trick said:hahaha Newegg just lowered THEIR price back down to $200...
This card is going nuts on the egg- From $175 to $230 to $200 to $280 to $250 to $200- all within about 10 days!!!
I would say no. MAYBE if you went to the x1950pro it would be a big enough difference but from everything I have seen, the 7800gs is not a big enough jump over a 6800gt to justify the price.buckbadly said:Would I notice a significant difference if I went from the 6800GT in my sig to a 7800GS? I'v been doing some looking and I am torn between the X1950 and the 7800GS. Just looking for someone that has made a similar leap.
The main reason for the lower temps is that the g71 cores run 1.1v 3d as opposed to 1.4v for g70 cores. something else to consider is ambient temperature, Its summer where I live, which is why I cut another hole and fitted a 92mm fan to the side of my case blowing 2/3 under the card and 1/3 over it, made a good 10c degree difference.Well, yes and no, I mean you see my overclock, that's at stock voltage. The biggest advantage to the 7800GS with the G71 core is temps, my idle temp is 40c, and load is 50c, that's with the huge overclock.
TeleMan said:Newegg has a great deal now - $209 with a $50 rebate.
Yup, for that price, a 7800GS is definitely worth it in my opinion. Make sure you tell us how it clocks when you get it!Jedi Mind Trick said:Yep, I was just getting ready to buy one from FRY'S when I saw this. Man did that make me
blitzkrieg1110 said:Make sure you tell us how it clocks when you get it!
Deadman93723 said:So, you are finally gonna get one...lol
Susquehannock said:Agreed. Had to pick one up myself. One last hoorrah for AGP !
