przemek1109
- May 28, 2023
Hello, recently I bought:
I'm a bit confused about the BIOS configuration:
Setting vcore to fixed 1.2v significantly reduces performance in CinebenchR23. The best option seems to be Level 2 in CPU Core Voltage Compensation.
I also tried setting an offset of -100mv. During CinebenchR23, with PL1=PL2=265W and Base Freq Boost=180W, vcore dropped from 1.28v to 1.24v. The CPU Package Power result was 195W, and the temperatures were around 89 degrees. However, the performance was lowered because e-core dropped to around 3.7-3.8GHz.
I'll be completely honest: I haven't noticed any differences while gaming, maybe slight ones in Warzone 2 (built-in benchmark) when PL1=125W, PL2=181W compared to PL1=PL2=235W (around 2% difference in FPS).
Temperatures while gaming: Warzone 2 around 60-63 degrees, Cyberpunk around 70 degrees. Do you think it's worth replacing the air cooling with a water cooling system like Navis F280? Or maybe a better air cooler like dark rock 4 pro? As for temperatures during the test (CinebenchR23), for the configuration with PL1=PL2=181W, it doesn't seem too bad at 76-79 degrees with CPU Package Power around 145-150. However, for PL1=PL2=235W, the processor gets quite hot, around 95-98 degrees, unless I lower it by -100mv (which has minimal impact on performance).
- B760M Steel Legend (I flashed the latest BIOS 4.07)
- i5-13600kf CPU
- DDR5 6000mhz 1.35v RAM
- Fortis 5 dual air fan cooling
- 1) Should PL1 be equal to PL2?
- 2) If PL1=PL2=181W, during CinebenchR23 stress test, I get 4.8GHz for p-core and 3.8GHz for e-core. The score is around 22700-22900. However, in all the reviews, they mention that by default, p-core should be 5.1GHz and e-core should be 3.9GHz, with scores around 23700/24000. Is there something wrong with my processor/motherboard?
- 3) I noticed that if I set PL1=PL2= at least 235W, then indeed, p-core reaches 5.1GHz and e-core reaches 3.9GHz, and CinebenchR23 scores around 23700-23900.
- 4) I tried experimenting with undervolting, but it doesn't work quite well on my B760M. I read that Intel blocked (limited?) undervolting, and it supposedly works with microcode 104, while mine is 115.
