Hello!
I just bought an IdeaPad L340 Gaming with theses specs: http://psref.lenovo.com/Detail/Lenovo Laptops/ideapad_L34015IRH_Gaming?M=81LK002FMX
Core i5-9300H (4C / 8T, 2.4 / 4.1GHz, 8MB)
NVIDIA GeForce GTX 1650 4GB GDDR5
8GB DIMM DDR4-2400
Chipset Intel HM370
256GB SSD M.2 2242 PCIe NVMe
It's freshly installed and got latest drivers for BIOS, graphic card, sounds card etc.
I dont got any anti virus programs or anything, just steam + CS:go.
I have changed to enable all cores/threads in windows, also performance mode. Closed Xbox settings. Tried to change all the NVIDIA settings to low/performance in the configuration.
The problem is I think Im lacking FPS, its kinda unstable it seems.
I got all CS:go settings to low. Running 1980x1080p in wide screen 16:9 and I got from 75-115 FPS.
A friend of mine got lower specs and can run it on stable 150-175 FPS with his computer.
Been watching computer temperatures and they go up to like 60-70 degrees maximum, also the computer makes pretty much noice (fans?) when performing CS:go or any other more demanding activity. Tried to lift it up from the surface with on old cooling device with fans, it got a little lower degrees but no difference in CS:go.
I ran 3D mark: https://www.3dmark.com/3dm/38533611
Novabench result: https://novabench.com/view/1801827
When I run 1280x720 widescreen 16:9 with same low settings I can get higher FPS, like 150.
I have tried with different ingame commands and running with these launch options:
-novid -tickrate 128 -high +fps_max 0 +cl_showfps 1 +cl_interp 0 +cl_interp_ratio 1 +rate 128000 +cl_updaterate 128 +cl_cmdrate 128 +mat_queue_mode 2 +cl_forcepreload 1 -nod3d9ex -nojoy
Any thoughts how to improve it?
Regards
8GB DIMM DDR4-2400
Chipset Intel HM370
Regards
