Are you talking about case exteriors? if so the colour of the case wont make a difference... however because it is metal that is painted it might trap in heat more then a metal unpainted case would.
Yeah, I agree that aluminum has a better look than most cases. You might want to take a look at the black aluminum coolermaster case. I am planning to order the Antec P160 case. I think both are sweet cases, but coolermaster is more expensive.
this is an age old question and it appears color and even material doesn't make a difference. Some people go for aluminum but I've read reviews where aluminum vs steel cases (exact same case) and there was no noticeable difference. Only the Steel cases are heavier.....
Yeah, I have a Lian-Li PC61 (black) and the case itself doesn't feel like it's radiating heat. Maybe aluminum cases will make a difference as components run hotter in the future, but they don't right now.
It would make a difference if the *interior* was made black as well. As current interiors are clear / reflective they are indeed barriers to radiation.
