XunknownX
Disabled
- Jul 12, 2003
- Palmdale, CA
Full Article - Overclockers.Com
From The Article "A New Nasty" - Ed Stroligo - 8/12/03
NOTE: This Information Is Edited :- Reading The Full Article Is Recomended
1) What is your opinion of this virus and the people who created it ?
2) Can Microsoft do more to protect its users ?
The Inquirer reports on a new virus you should take very seriously.
The reason why is that you don't have to do anything dumb to get infected, like get happy fingers when you get email attachments.
Rather, it comes looking for you.
The Inquirer article provides the necessary links to find out more about the virus and the necessary patches/files you need to prevent this from happening and fixing it if it already has.
What it doesn't mention is that a minute or two after booting into Windows, it tells you it's going to shut your machine down after sixty seconds, gives you a countdown, and procedes to do just that.
If you have just one machine handy, it leaves you with a Catch-22. You can't retrieve the necessary files fast enough before the machine shuts down, and if you go into Safe Mode, the virus isn't the problem, but then you can't access the Internet to get the fix.
How do I know this? I just had to do a house call with someone with this problem. It was simple enough for me to go home and get the necessary files, but it may not be so easy for you.
In any event, better to prevent this from happening to begin with. You can get the Microsoft patch for WindowsXP here and Windows2000 here.
If you're already infected, go here for a fix tool and further instructions.
Before fixing an XP system, you ought to turn off System Restore first. The Symantec link on how to do so doesn't work, but this one does
