Jeff Evans (Dec 17, 2000 07:20 p.m.):
I would not waist my money on a Blorb. Just superglue a Socket7 sink on their }>
Bobby Manus (Dec 17, 2000 10:26 p.m.):
Super glue? Are you joking or will something like that actually work? Cuase I plan on overclocking my Geforce 2 GTS and I dont want to waste 170$ cuase I took a joke seriusly :-D
If you read skips post again you will notice he said "Epoxy" not "Paste". Not sure if your confused or not, from your post imediatly following his it sounds like your confused, or maybe you just read his post wrong. Don't waste money on Arctic Silver paste. I think that it is a horible "value".Bobby Manus (Dec 17, 2000 11:54 p.m.):
Ugh, found some thermal paste for $1. Will this cut it? I dont see any artic silver thermal paste at pricewatch, ill look around at places like tomshardware. But what is the diff of thermal paste and this artic silver that you speak of? Im ok with paying a couple extra bucks, thermal paste is only 1$, even I can afford that ;D
It depends on what MX you buy..... I generally just replace video card sinks for any of my customers that are hardcore gamers, even if they don't OC the card. I do this because I find that 3 or more hours of Q3A get that lil heatsink very HOT! To take the old one of put the card in the freezer for 15min.... then grip the heatsink with a pair of channel locks and twist a little and pull up. Be warned: It will make a very disturbing SNAP! Later if you have to return the card and have only gluesd the new sinks corners...... you can remove the new sink the same way and put the old one back on. But I've never had to return a card unless it was DOA.Bobby Manus (Dec 18, 2000 01:15 a.m.):
Ok im still pretty lost. Got a link with some perrty pictures? They generally clear all this up. I understand what you mean though, makes sense, thernal paste the center and then superglue the 4 corners, put small weight one it 30 min, that part seems simple enough. Problem, how do you take off the hsf? Razorblade and alchohol? What does the hsf on a graphics card look like? Is the one on the MX a good one? Or should it be replaced? Once again all help is greatly apreciated!
Just had an idea...... blow a wad on a PEP66 with delta fan. And afix it to your MX the same way I afixed the Socket7 cooler to my V3. Then throw a little 53watt peltier on it and see what she really has! }>SMuH (Dec 18, 2000 03:26 a.m.):
why should I glue a heatsink / fan to my gf2mx if i can use those "push-pins" to fix it. When I had to exchange the hsf on my Asus 6800 i never thought to fix it with glue... and of course the 12$ for a blorb could be a waste of money, but for a card like the asus 6800 ...
