- Jul 25, 2003
- Rio de Janeiro
Give the NB 1.7-1.8v, also are you trying to boot at 222? Or using clockgen? I'd recommend trying clockgen if you want a high FSB. I run 9x290 for 2.6, but I don't boot at that I boot at 9x201, then clockgen does the rest when I hit windows. Best thing to do is see where you CPU is stable, and then drop the multi give the ram some space run a ratio 3:2 would be good to start with, and see how far that FSB will go. Also I see you are running Sata, this means you can't go past 300FSB because that is where the pci lock (for the Sata atleast) craps out.
