BSOD PFN LIST CORRUPT/MEMORY management
ATMINSIDE
No, I mean to boot the system to a Linux Live CD. Ubuntu is a common choice for this.
shadowdr
Senior Member
Try running the SFC /scannow command in the run box.
I can't read any of the dmp files as they open in MS Word but normally if there are no memory errors it is a driver. Does it have the most recent bios update?
You can also install Who Crashed and check it every few days, it may point to a specific cause.
A
azzer391
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
description: NT Kernel & System
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Mr.Scott
Beamed Me Up!
Re-set ALL clocks and voltages to stock. Dump ALL the drivers. Repair install the OS using the OS disk. Re-Load correct drivers.
