silvershad0w said:I'm compiling an article now on how to build various Peltier PSU's. All the designs I am submitting are LINEAR. The switching supply design is on hold, as the time required for such a design project has become prohibitive in recent days. The projects included in the article should meet 95% of your needs. Suppliers for the components are included in the article, all U.S. based. The article covers the following:
#1 - Unregulated linear supply for single 156W/226W peltier (12-15V Peltiers)
#2 - Expanding the first project for multiple Pelts
#3 - A regulated linear supply for 172W Pelts (24V pelts)
#4 - Completing your project - incorporating goodies for powering fans, controlling pumps, and starting up with your PC. Includes a PWM schematic, providing variable speed capabilities for fans.
The article will take some time to assemble... In the meantime, anyone that can provide vendor links to incorporate into the article, for things such as Transformers, Peltiers, Heatsinks, capacitors, diode bridges, etc. Post them here. They will be included in the article. I want this project to be accessible to the masses, so the easier it is for Joe Sixpack to get ahold of parts, the better. I'll provide some more details later on, as to specific parts to look for, etc.
From the front page article by silvershad0w
Note: International builders with 200-240 volt supply voltages can use a 100-120V primary transformer in most cases. Just note that as above, where the output voltage changed considerably with a narrow change in mains power, a large jump (effectively doubling) in the primary supply voltage will cause your secondary voltage to change by a far greater amount than what I had with my setup. This may be helpful for you to find an appropriate power transformer.
Since87 said:I read, (actually, more like skimmed through) the front page article.
Overall a nice article.
A few comments though.
This is not likely true, and without use of a proper fuse, might be dangerous. Any given transformer core will only support a certain voltage per primary turn before the core will saturate. Once the core saturates, the impedance of the core will effectively drop to the resistance of the primary winding itself. If this occurs, the result will be huge current draw by the primary during a portion of the AC sine wave.
There are transformers that are designed for 120V or 240V and 50/60 Hz operation. They have two separate primary windings. When using them with 120V you connect the two primary windings in parallel. When using them with 240V you connect the two primary windings in series. (They also have a large enough core to meet their specs at 50Hz.)
I've seen recommendations from TEC manufacturers to keep the the ripple below 10% to avoid shortening the TEC's lifetime. Considering the result of TEC failure in this case, heeding this recommendation seems wise to me.
Have you measured the efficiency of your supply? If you run a 226 Watt TEC 24/7, the money paid for wasted power would probably pay for one of these in well under a year.
