- May 13, 2010
Well, after spending the last 6 months with my midtower being fully water cooled and having 2 gpus crapping out on me I have decided that I need a full tower for the ease of being able to work on things.
I bought the midtower honestly by mistake, then I kept it because everyone told me I was crazy to think I could fit a full dual loop inside of a midtower with 2 cpu's so I went ahead and worked my *** off for a week and I got everything to fit.
But now I am going for convenience and a clean build. I had planned to sleeve everything and clean up all the wiring but with the gpu issues I never got around to it.
My new build will feature a DF-85 case which a lot of people don't like but hey this isn't your box now is it?
I chose the case because I like the front fans, and its a 1200 with the fans moved farther forward which makes working inside the case a little easier.
Here are the system specs
Asus z8na-d6
2 x Xeon Nehlaem 2.26
24gb ddr3 patriot memory (long story why I have 24)
corsair hx1000w psu
nvidia geforce 9800gtx+
2 x wd 1tb HDD
2 x kingston 128gb v-series SSD x2
DF-85
I will be adding a raid card, and 2 more ssd's after x-mas
Watercooling specs
2 x Swiftech Apogee XT
2 x Swiftech MCP-655
2 x HW 360gtx rads (120.3)
slimfit res
Ek Full gpu waterblock
Custom nb/sb chipset
New box will be all compression fittings
You can expect build pics of the new box to start next week. I ordered the case today, and I also ordered the new rads and fans today.
I will be ordering all of the fittings next week once I figure out what I need.
Untill then, here are some pics of my current setup.
Dont mind placement of anything or the wiring it was supposed to be temp until I was caught up with work and able to work on it.
Asus z8na-d6
corsair hx1000w psu
2 x wd 1tb HDD
DF-85
Watercooling specs
slimfit res
