building my own AMD dually - tons of pictures (56K warning!)
wquiles
Dallas, Texas
Here is my own “adventure” in building an AMD dually following Chris' awesome How-To guide:
http://www.ocforums.com/showthread.php?s=&threadid=221503
My post here is not meant to replace Chris' work but rather to complement his work with additional pictures. I hope you will find this useful.
Gather all components:
W
wquiles
Dallas, Texas
Getting ready to fit the two large 90mm fans:
Initial prime95 (two instances) while looking at Motherboard monitor (I installed Win2K prior to this with a single HD and the DVD player working as CDROM for the install medial):
W
wquiles
Dallas, Texas
Remember the safety glasses:
Sparks fly:
All done on the back:
Do the same on the front one:
Taking the sharp edges off:
W
wquiles
Dallas, Texas
Make sure you clean all metal particles that could short electronics later:
Line up holes in motherboard with holes on case for standoffs:
W
wquiles
Dallas, Texas
Remove rear case openings depending on what are you are going to use:
Line up motherboard and make sure all holes line up with standoffs and bolt everything down:
W
wquiles
Dallas, Texas
Add hard drives/cables:
Make sure everything works and then close up the case and test for stability again:
(dually on the right, old PIII on the left)
Enjoy your new AMD dually !!!
Thanks Chris for all of your help and others here in the forum for the support/encouragement :)
William Quiles
(wquiles)
diehrd
Senior SMP Gawd
NY
I am confused...lol... If ya started with 1800+ why after the socket mod ar ya at 1800+ ? ?
W
wquiles
Dallas, Texas
diehard,
I should had put more detail. The front side bus was set with the motherboard jumper to 100Mhz in those two pictures. Once back to 133 I was then getting 2000Mhz, or 2400+. At FSB 150Mhz I hit 2250Mhz. Sorry that was confusing :(
W
wquiles
Dallas, Texas
I did not keep really good notes on the prices I paid, but approx:
- LCD Display: $549
- motherboard: $200
- CPU's: $65 each
- Power supply: $100
- Heat Sinks: $30 each
- Artic Silver: $4-5
- Memory: $230
- Case: $40
- HD: $60-70 each
- Video Card: $50
- RAID Card: $75
- DVD Burner: $80
- Floppy: $5
- FANS: $6-8 for the 92mm and about $10-12 for the 120mm
- cables: FREE (had many already)
=> So approx. $1100 without the LCD display.
I bought this stuff over a 4-5 month period of time (many times waiting for stuff to be on special and/or with rebates), usually one or two things at a time. It was hard to do (as I wanted to start building the dually!) but I had a budget I wanted to follow :)
