andyrgardner
- Nov 23, 2017
That isn't the case. I've tested it and it works?
PWM fan (4 cables) Controller circuit with adjustable duty cycle from 2% up to 98%.
This one actually is the same as Nidec's circuit above, its just I added PWM signal booster to cope with fan that might suck higher power than normal at the PWM out that will degrade it like Brutal's Sanyo Denki fan case.
Note : Actually that 556 IC is just two 555 ICs packed in one IC body, you could use two separated 555 ICs too,
Another version for purist who wants pure 0% (zero percent) up to 100% duty cycle. All connections to power (molex) and fans are the same as above circuit.
This circuit has an additional IC called comparator, it uses LM311, you can change it with other popular comparator ICs like LM393 or LM339, although the pins assignment are different, just map them accordingly.
Update 14th Aug 11 :
Single controller with 2 normal outputs for normal pwm fans and the other one for the inverted pwm fan.
http://www.overclockers.com/forums/showpost.php?p=6935139&postcount=834
Update 9th Aug 11 :
Kick Start Add On
Read the detail explanation here -> http://www.overclockers.com/forums/showpost.php?p=6931080&postcount=822
Also a demonstration video of Kick Start mechanism in action -> http://www.overclockers.com/forums/...ires-PWM-fan?p=7116335&viewfull=1#post7116335
Both circuits are using PWM frequency that is set according to FormFactors standard for 4 wires PWM fan -> http://www.formfactors.org/developer/specs/4_Wire_PWM_Spec.pdf
I need to be able to control all 5 fans, that circuit seemed to be the one to do it.
Any help?
Thanks!
Scott
Can anyone help me?
Hi Guys,
Here is a build log with the completed board, order link from Osh Park, and a complete bill of materials. I hope this helps anyone trying to build this circuit!
https://neonkev.com/2018/12/26/a-small-circuit-discrete-pc-fan-pwm-speed-control/
Here is a vid of it in action:
Enjoy!
Is that a 78L05 voltage regulator on your board?
The voltage regulator I'm using is a TS2938CS50. It is an 8-SOIC SMD package, and can regulate up to 30 volts on the input side down to 5 volts output.
I also ordered a few TI LM2936HVMAX-5.0/NOPB voltage converters after the fact, as I have a few 48 volt fans I wish to use with this circuit. This regulator accepts up to 60 volts on the input for a fixed 5 volt output. Same package and pinout as the TSMC.
Here is a bill of materials for all the exact parts I used in demo:
https://drive.google.com/open?id=1iwtzoplmZF2ddBEZk2xw1l7AbuUUEhFi
