- Apr 4, 2011
Hi im trying to get my Delta's to work ive a zalman PWM mate on a loom ive rigged up so powers from molex for 12v and 5v etc but won't respond.
Tried grounding across from black to blue with a wire which had no result so wondering
what or how does the delta pwm circuitry work/configure? as tried an old intel stock cooler and that worked ok chopped that wiring/plug off to use to fan as know plug pins make contact ok and connected to fan wiring.
I like that what looks like a bay controller on InVains posts as thats the sort of thing im looking for as going to run 3+ sets of fans.
Anyway guy's keep up the good work.
try to hook your delta's yellow wire to either ground or 5v,
usually delta use the blue wire as the tacho-meter
as your drive bay controller project,
I recently build this controller for a friend o' mine, consists of 2x pwm and 2x analog controllers:
these are the connectors for the pots:
and the pcb will fit nicely on a trashed old cd-rom case
