Hey bing...
I'm thinking this PWM controller would be a good little weekend project for me this holiday season; and a good way of gaining full control over my delta fan (it's on the PWM header of the mobo right now, but I'd like to be able to control speed better)
I was looking at your diagram for the 0% to 100% circuit on page one and see that C5 is a polarized cap at 47uF and 10V...
Am I safe to assume that the other caps are not polarized and at 10V as well?
Would there be any benefit from getting caps other than the regular ceramic ones?
On the Pot... Will any run of the mill linear pot with the 10K ohms rating do? Or should I look for something in particular?
Thanks
Sebastian
Great, another participant jumps in !
Yes, that C5 is polarized cap, as you can see at it's symbol compared to other caps, also for common cap that is easily to find, 99% chance you will get a polarized one rather than non polar cap.
With this cap's size and a thru hole component (meaning component with legs), it is unlikely you will find a non polar cap, though they exist but its quite rare and most of them if non polar is smd version (surface mount cap), which is not a requirement in this circuit. Anyway, should you found a non polar version, its fine too, but I doubt it since they're much2 more expensive than the polar type.
Value wise, even its 47uF 10 Volt, any cap above 47 uF (not too large) and working voltage minimum or above 10 V will work fine too, like a 100uF 16 volt cap is ok too.
About the potentiometer, as long they're 10K and linear version, it should work, and that military pot style of yours definitely will add up the "bling" factor
, really curious how it looks, if you had a chance, please post the pic of that pot.
