- Mar 29, 2013
- North Carolina
I've been looking on the internet and havent been able to find any info for my problem so i was wondering if i could get some help here.
I have a Asus p8z77 v-pro motherboard and a Thermaltake chaser mk-1 case.
so what i was wondering if there is anyway that the motherboard can control the colors of the fans since they are color shift. The case comes with 2 color shifts and i plan on adding two/three more so i would like to be able to control the speed of the fans more strictly using the motherboard.
The case has a fan controller built into the top-front and it works well for the two color shift fans so far but i would like to control the speed better by the motherboard if possible.
If I cannot control the colors using the motherboard, is there anyway that i can connect all 4-5 color shift fans to the fan controller in the front. I believe the two fans that came with the case are plugged into the same 3 pin plug on the controller and there is one 3 pin socket left. I was thinking that i would have to buy a splinter and it would allow me to connect two more the the last 3 pin plug on the controller.
If more info is needed just let me know
Motherboard: ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819 )
Case: ( http://www.newegg.com/Product/Produ...pk=thermal take chaser mk-1&IsVirtualParent=1 )
