So these fan hubs are 3 pin 10 connection hubs, with an output to a controller.
Question is, should all fans connected use all 3 pins, and does the hub actually provide the circuitry for the RPM off its output connection?
Should I only connect 1 fan with a 3 pin for RPM purposes?
Info: Rated for 30W, using GT AP15, wont fill all 10 slots. But will be using a fan controller.
Advice?
Advice?
