Hello Everyone,
Like the problem states I am having problems running all 16 GBs of ram at 1866 in my newly built system. First off I will list my system specs in case any of it is relevant to the problem.
Intel Core i7-2700K
Gigabyte GA-Z68XP-UD3
2X CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9
2X OCZ Vertex 3 130GB SSD
2X Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM
Asus GTX 480
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Pro
VisionTek Bigfoot Killer 2100 NIC
Antec TruePower Quattro TPQ-1000 1000W PSU
Like I said previously this is a newly built system. I put this system together for the first time about two weeks ago. In its first iteration it only had 8Gbs of RAM. At first I had problems running that at 1866. I would go into the Bios and load the XMP Profile1 and the system would not boot. It would give me an error about the RAM frequency then default to the 1333 speed. The 8GBs are in 2 4GB sticks. I removed one stick and could get the system to run the one stick at 1866 in all Four RAM slots. I switched the sticks out and could get the other one to run at 1866 in all Four slots. The problem ended up being I had the two in Slots 2 and 4, instead of the recommended 1 and 3. I installed the OS and everything was GRAVY. I was happy with it.
But then I began thinking how much better it would be if I had 16GB of RAM in it. So I ordered another 8GB of the same model of RAM. When it came I installed it in Slots 2 and 4, and didn’t have to change anything in the BIOS, all 4 sticks were running at 1866. At the same point I added the two SSDs to the mix so I had to reinstall the OS. Once the installation was done, came the numerous BSODs. It seemed like every code was different but had something to do with memory. My thinking immediately went to I got a defective stick in this latest batch. So I took the old RAM out and placed the new RAM in 1 and 3 and reinstalled the OS. It is rock solid, with the latest sticks running at 1866. So apparently all 4 sticks work great at 1866 when there are two of them in the system. When I add all 4, that’s when errors pop up in the OS side of things.
The only setting in the Bios that I altered in relation to memory is selecting Profile1 in the XMP part, just that one setting.
I have a feeling, or maybe it is just a hope that this is just some setting I never set in the BIOS that could get this system Jiving. PLEASE HELP!!!
Intel Core i7-2700K
Asus GTX 480
