- Apr 27, 2003
- Thread Starter
- #21
If you have your own cable modem that should not be an issue.
What kind of router specifically do you have?
EDIT: No ports open circumventing the router either? If the desktop computer is hooked directly to the modem you should have your external IP for the computer and not a 192.168.1.xxx
You will not need to forward any ports like that, just make sure they are open in your firewall.
the router is from comcast it is a wnr1000v2 i tried using my wrt54gl but it wouldnt work cause it has dd-wrt on it, also my desktop did show the internet ip but i could not ping or get a reply from a certain port and when i was connected to the modem it showed a ip starting with 74 or 75 and when the modem is connected to the router the ip is this 68.52.19.** its very strange
