Hey guys,
I recently set up a system with the following components:
-i7 920 D0 (Bloomfield) CPU
-MSi Big Bang X-Power X58 Motherboard (v1.6)
-3x2GB Corsair Dominator GT (CMT6GX3M3A2000C8) 2000MHz RAM
-MSi GTX 480
-1KvA SilverStone PSU
So all the hardware is working fine; no complaints.
However, my OCing experience with this equipment has been....interesting so far.
My goal has been to get the CPU clocked to 4 GHz and the memory at 2000MHz. So, ideally, the bclk = 200 and multiplier = 20.
I know that there are a number of factors to keep in mind (mainly VCore, QPI/VTT and RAM Timings) which I have researched and tested with. But, irrespective of what settings I have tried or changed, I cannot get my dream configuration working.
At the moment, my machine is set to the following:
BCLK = 193
CPU Vcore = 1.344
CPU PLL = 1.950
QPI = 1.59
DRAM Vcore = 1.65
DRAM Timings = 8 : 9 : 8: 24 : 1T
Multiplier = 21 (EIST enabled to allow 21x)
Memory @ 2000MHz (@ 5x Ratio) (2:10)
Total Speed = 3860 MHz (+ 1 core @ 4053 MHz due to EIST)
The above settings are stable (ran LinX with no errors; I read that the latest version of LinX is a more accurate testing method than Prime95 but also tested with Prime95 and stable).
But when I change the BLK to 194 or above, it is no longer stable; irrespective of what settings I change.
Now, the only settings I manually configured were the VCore, DRAM Voltage and DRAM Timings....the CPU PLL and QPI/VTT were set to AUTO in the BIOS.
This is what confuses me a little, though. In the BIOS, the max value for the QPI/VTT I can set is 1.52....yet, when left on AUTO; and checking the value in Windows via the MSi Control Center, it says it's set to 1.59 (of 1.60 absolute max in Control Center). I also get the identical value when settings my system to 200x20.
Again, I have experimented changing the RAM timings to "loosen" them a little but it doesn't help... and the above written timings are what I am running on on this stable overclock. When running at 200x20, LinX will crash after 3-4 seconds, essentially freezing my entire system and requiring a cold boot or indicate errors....and eventually have a system lock up.
All the other settings in the BIOS, left on AUTO, register that they are set to default values (i.e. IOH etc).
I also tested multiple configs, leaving the BCLK @ 200 MHz, where I change the multiplier to 12x and going up (thus CPU running @ 2400 MHz and incrementally being increased) and/or changing the RAM Speed (1200MHz, 1600MHz).....I still have the same problem.
....so the only thing that I can think off is that either i'm not doing something correctly/missing something or my CPU (or hardware config in total) does not like running above a BCLK of 193.
That's the jist....if there is any other information you'd need to help out, let me know.
Hope I can sort this out.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
r2rX![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-MSi GTX 480
BCLK = 193
CPU Vcore = 1.344
CPU PLL = 1.950
QPI = 1.59
DRAM Vcore = 1.65
r2rX
