- Nov 7, 2004
I've a Xclio case which has 2 large 250mm fans on the side panel one is starting to hit the plastic that holds the fan in place and I've tried to bend it in position but after a while it goes back in to the same position where it slightly hits and it gives off this annoying grinding, now I can't seem to find the size of these fans in the Uk when I google search it's either a smaller 200mm fan and use cable ties in the corners to hold the fans in place or try and find 250mm ones. Ebay shows nothing I wouldn't mind changing them for more silent ones because this case was passed down a lot to a few people then to me and so I'd rather change to new now then suffer finding some when they have gone, I can manually speed them up and at the moment temps are in the mid 20's to 30's some days 23-28 and could get hotter so again would be good if I can replace them.
