Pics of your bios are very helpful.
Reset your CPU frequency to 200 and your cpu multiplier to stock. I.e., let's start from scratch or baseline now that I see you have more OC options in your bios than you realized.
I note from your sig that you are running DDR2 1066 ram at DDR2 667 but that line is grayed out. What are your choices in the line above that where is says "MaxMemClk"? If you change that does the line below it become active? In this case, I wouldn't go all the way to DDR2 1066 but I would bump it up to DDR2 800 if you can. Even though the ram is advertised to do 1066 speed an awful lot of people find the computer actually isn't stable at that ram frequency. This is probably due to weaknesses in the Phenom 1 integrated memory controller.
To change the NB frequency go to : CPU-NB multiplier. Change from "auto" to "manual" and adjust the multiplier number so as to remain as close to 1800 mhz. as you overclock.
To change (lower, lower in this case) the HT frequency go to K8<->NB HT Speed. Same as above with NB multiplier. Keep it at or below 1800 mhz.
It is probably a good idea to give the CPU NB voltage one little bump.
Why are you running DDR2 1066 ram at DDR2 667? In this case, I wouldn't go all the way to DDR2 1066 but I would bump it up to DDR2 800. Even though the ram is advertised to do 1066 speed an awful lot of people find the computer actually isn't stable at that ram frequency.
Raise your "Memory voltage" to the mfg. recommended amount for DDR2 1066. You're not running it that fast but it should give you a little cushion at the speeds between DDR2 800 and DDR2 1066 that you will be working with.
As you raise the "CPU frequency" the ram speed, front side bus, HT, NB CPU all increase in lock step. If you had a black edition cpu you could increase the cpu multiplier without affecting those other component frequencies. That is the value of the "BE" capable processors: you can speed up the main performance component without putting additional stress on the other stuff. But since you don't have a be cpu that is neither here nor there. Anyway, as you raise the CPU frequency, adjust the HT and NB CPU frequencies so as to stay around 1800.
You will also need to bump up your CPU voltage in increments as the frequency increases. You can easily and safely go as high as 1.375v AS LONG AS YOUR TEMPS DON'T GO TO HIGH. 60-65 Celcious is safe when stress testing FOR SHORT PERIODS, not more than 60 min. I would say. I highly recommend you get better cooling as soon as you can.
The one bios feature you are missing that would be helpful is the ability to change the ram timings (latencies) but with the limited headroom of your cpu it prolably is a non issue.
Hope this helps.
