Hey guys,
Recently just built my PC last month using case http://www.phanteks.com/Enthoo-Pro-M.html
The problem is it only came with one rear fan. And I plan on adding some fans to keep the system running cool. I plan on adding an intake fan (140mm) or two on the front and an exhaust (140mm) on the top.
Would appreciate it if I could get some suggestions on some fans. Not really sure what fans are good and which are not as there are too many out there. And also, Is it true that exhausts should have high CFM while intakes should be static pressure?
Thanks a lot.
Thanks a lot.
