get a standard case fan and simple screw it into the holes you normaly use for pci cards make sure you get the right sized fan for the amount of pci slots you want to cover and you may need to buy some longer srews
pci slot clooing is generic it can be used for... sound cards too?.. for the really catious person(s). also the more fans in the case the better air flow thus cooler cpu temp
