- Apr 21, 2007
- Yorktown, VA
I am looking to upgrade my 7 year old Antec. I need a full tower with plenty of drive space and needs to have enough room for maneuvering water cooling tubing. I would need to have room on the top to place a 3 fan radiator inside the case roof blowing out. I need something for under $100, I know I am asking quite a bit but there has to be something out there. I am not looking for anything flashy or fancy just lots of space and drive racks.
I have been looking at this one but what I don't like is the side mounted PSU rack leads me to believe it is too thin (8.1") and will probably make it difficult to have water cooling tubing in there. Plus I am not sure if the triple fan radiator will fit inside the case (roof).
http://www.newegg.com/Product/Product.aspx?Item=N82E16811125468
Thanks
Thanks
