Looks like oxidation from brazing. Sand it with very fine sandpaper and then polish the surface to remove the oxidation.Whats up with the base on your block? In the picture it looks black, is that just because of the camera or did you do something extra to your block?
Dell_Axim said:I see a yellow dot in the sight glass. I'm not sure how yours is, but I think yellow means air in the pipes. Purge the pipes to prevent the oil from degrading. In particular, ester oil reacts with air to form undesirable contaminants.
BTW, I think you got the evaporator direction reversed. In general, the TXV should connect to the bottom and the compressor to the top. This way, liquid refrigerant will tend to stay in the evaporator instead of flowing into the compressor.
Dell_Axim said:Looks like oxidation from brazing. Sand it with very fine sandpaper and then polish the surface to remove the oxidation.
Ad Rock said:Looks great man.
Really nice job on the case, I am digging the plastic case "feet".
Again looks awesome man, keep up the good work!
catkicker said:Yep, with all the brazing done it needs to be cleaned up and insulated.
The block has been insulated with armaflex to protect the processor and MB from condensation.
Ad Rock said:Why/what were you brazing to your waterblock? I was under the impression that chillers used a "soft" tubing to connect the res and the block? Your not using copper tubing to make the connections are you?
Also why would you insulate before lapping the base of the block? Did you insulate just to get a dry-run in and test the mount?
catkicker said:no brazing on the swiftech block. With very cold coolant flowing through the block it needs to be insulated so condensation does not form on the block and then drip onto the computer componets.
