- Feb 2, 2015
Hi. I know very little about building a custom gaming pc. I went to http://www.build-gaming-computers.com for a place to start. I have used the recommended custom gaming builds as a reference for what I would like to build and how much I'm willing to pay. So far, I have came up with a build that's somewhere in-between the low and mid range build. I'm not sure if these parts are compatible with each other or if I should replace these parts with something better or compatible. My budget is to spend no more than $1,000.
Motherboard - ASUS Micro ATX DDR3 2600
(http://www.amazon.com/dp/B00K2R6BQS/ref=psdc_1048424_t1_B00K2R6C9Y)
CPU - Intel Core i5-4690 3.5ghz
(http://pcpartpicker.com/part/intel-cpu-bx80646i54690)
RAM - Kingston HyperX Fury 8gb DDR3 1600mhz
(http://www.amazon.com/Kingston-Hype...ds=Kingston+HyperX+Fury+8gb+DDR3+1600mhz+CL10)
Video Card - EVGA GeForce GTX 960 SSC GDDR5
(http://www.amazon.com/EVGA-GeForce-...2834456&sr=8-15&keywords=evga+geforce+gtx+760)
Hard Drive - Western Digital 1tb
(http://www.amazon.com/gp/product/B0...iveASIN=B0088PUEPK&linkCode=as2&tag=buildg-20)
Optical Case - ASUS 24x DVD Burner
(http://www.amazon.com/gp/product/B0...iveASIN=B0033Z2BAQ&linkCode=as2&tag=buildg-20)
Case - Rosewill Redbone or Blackbone ATX Mid-Tower
(http://www.amazon.com/Rosewill-REDB...de_a_smtd&showDetailTechData=1#technical-data) (http://www.amazon.com/Rosewill-Stee...0690&sr=1-2&keywords=rosewill+mid+tower+cases)
Power Supply - Corsair Builder Series CX 600wt
(http://www.amazon.com/dp/B0092ML1SC/ref=twister_B0093XCRXS?_encoding=UTF8&psc=1)
I don't need the best resolution and frame rates for my PC gaming. I want play Space Sims, MMOs, and Strategy games at medium settings with little to no problems without having to upgrade anything within the year and or into next year because I do have a Xbox One for all other console genres.
