- Apr 1, 2004
- Toronto
bing said:Of course since we're talking high Amps here, especially on TEC, let see this pic below and let say from your installation you measure the voltage at 2 locations which is at at the power supply output and at the TEC termination cable like this.
If your result is really like that, I would say you must dump that cable since it is dropping 1 Volt across it ! For high current device, it is very-very bad !![]()
How bad ? Let see....
Let assume from the manucature specification that the TEC is running at 15 Amps when at 12 Volt.
The voltage at Tec at 11.995 Volt which is very close enough to 12 Volt and it is quite safe to say it is also consuming 15 Amps as per factory spec.
Now, the voltage right at the power supply output is 12.995 Volt (yeah, assuming it is a bit off) and through the cable it drops 1 Volt across it and arrived at the TEC at 11.995 Volt.
This means the cable alone is eating up the power at -> Watt = Volt x Amp = 1 Volt x 15 Amps = 15 Watt !!!!![]()
The TEC power -> 12 Volt x 15 Amp = 180 Watt vs 15 Watt , see how bad it is almost 10 % of power used by that dumb cable !
That is why most high current devices got hunky cable to minimize this voltage drop and also if possible make it as short as possible since we don't want it to act as a stealthy resistor that steal up the power !![]()
Say, just for a moment, you wanted a cable to consume that much wattage. What would its characteristics be? I'm thinking a large diameter and quite long, correct? As small diameter cables pose a fire hazard, I'm hoping that to be the case.
Why would I want the cable to consume some of the wattage? Well, I would like to run a 437watt TEC but around 18 volts. The problem is that I only have a 24 volt power supply (well, actually it's 2 X 12volt ones that I'll wire to give 24volt) that can only drop to about 20 volts delivery. If a long, wide cable would drop that another volt I could could get closer to my goal of 18volts.
I had a thread over XS asking about voltage reduction ( http://xtremesystems.org/forums/showthread.php?t=134757 ) but it didn't seem to come up with any new ideas on the subject. I'm just looking at cheap, easy ways to increase the efficiency of TEC's.
