- Feb 22, 2009
87dtna are running comparisons, it seems that different boards have a little different options. Mine for example allows you to enable C4/C6/C7, where his only has C4/C6. On my board, that is what gives you a X24 boost of power during single threaded apps. I have run Super Pi using Turbo, mine at 175 X 20 Turbo and his at 4200 MHz and it seems that my Score was a couple milliseconds faster.
Regardless, at 1.5V+ you really should consider Water Cooling. My temps in prime hit 90 degrees within 45 min. I didn't crash or fail, but I choose to not run it that high, I have my volts backed down under 1.5. His must just be a better Chip.
With the EIST/C1E/C4/C6/C7 enabled it allows your processor to underclock like speedstep did. My Idle temps with it enabled dropped down to 27 degrees, but when I overclock to 190X20 or Higher with those settings disabled, the Idle temps remain between 35-40 and they do not speedstep.
I think the verdict is still out on how to overclock the i5.
