- Apr 6, 2009
- New Jersey, USA
Following the guide shown on this website, I tried overclocking the core i7 920 d0 I got from microcenter a month ago.
I am currently using an Asus p6x58d premium updated to the most recent BIOS.
Here is the relevant hardware:
6 GB Corsair PC12800
2xGTX 260
PC Power and Cooling 750w PSU
Swiftech Apogee XT waterblock
Swiftech MCP655 Pump
I was able to achieve a maximum stable bclk (Prime 95 8 hours, LinX stable 20 passes) of 210 at 1.350 QPI, according to the first section of the guide. (I did manage to get it to boot at 215, but I never was planning to take the system to above 4.2 ghz so I wasn't going to bother with getting it stable). I decided to skip to memory overclocking step and instead just use a really low multiplier because memory overclocking usually doesn't pay off in terms of the time put in.
I am having difficulty getting 4.0 ghz overclock stable at 1.325 vcore. At 1.325 vcore, I managed to get the system stable for about 5 hours in Prime 95 before encountering a BSOD. The system was stable for 32 LinX passes before giving an error. This is normally acceptable for me, but I was planning to do folding on this rig, so I need even more stability.
Is it abnormal for this system to require so much voltage just to get stable at 4.0 ghz? I can boot to windows at 1.250 vcore but it simply isn't stable.
Another observation: I never seem to get any failed tests in Prime 95, only BSODs. For the most part they are two letter/number combinations like 9c (don't know what to do, i usually just increase the vcore), but occasionally i get some like 101 (indicating vcore increase needed) and 124 (qpi increase?).
2xGTX 260
Code:
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[191]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1531MHz]
UCLK Frequency.........................[3063MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.32500]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.35000]
IOH Voltage............................[1.36]
IOH PCIE Voltage.......................[Auto]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
