Core X71 fit an E-ATX gamble???
DefiantReaper
Indiana
So i was going to gamble and see if the Thermaltake Core X71 will fit the X99 Godlike Gaming mobo...
The case technically only supports the ATX but i think itd fit. as its a monstrous case.
If not then i guess ill have to go the z170 route and get the xpower titanium but id really like to have the extra 2 cores
ATMINSIDE
Why can't you use an X99 ATX motherboard?
Doesn't look like you'll be able to use any cable management if you use an eATX board.
dylskee
Central MA
Yeah the E-ATX will run about another 1/2" wider and cover about half of the access slots for cable management but I still think it will work.
EDIT: I have this case and I can send you pictures and dimensions if you'd like?
DefiantReaper
DefiantReaper
Indiana
Yeah man thatd be awesome! Id love some pics
I plan on getting the Thermaltake wp100 after its released and i can see some reviews on it and figured that the core x71 was the next pick for me and its $300 cheaper lol
maxfly
wut he sed :D id post pics but its to early to mess with my camera. seriously what dylskee said is spot on. altho there is a new x71 variant https://www.newegg.com/Product/Product.aspx?Item=N82E16811133349&ignorebbr=1 that does accept eatx mbs but its alot shorter
